What key to switch the tools
What key to switch the tools (i.e. wire, position, edit text)? As I remember Ctrl + somekey.
(2,865 Views)
Depending on the enviroment you are talking about but for Windows you use the "Tab" key to go between every tool and the "Space bar" to go between the 2 most common tools.
(2,865 Views)
Several keys do change tools. Tab cycles through the four primary tools
for a given window. The space bar cycles between the two primary tools.
Holding the Shift key and right clicking or otherwise invoking a popup
will show the tool menu rather than the function/control palette.
Greg McKaskle
(2,865 Views)
