Hello Michael,
Thanks for your help. I am using IS Express V2.12. You have described
exactly what I want to do. However, I cannot find a place to tell IS to take
the INSTALLDIR path from the registry. When working with IS, I sometimes
switch back and forth between the IS Express app and just editing the .iwz
file in notepad, so I am pretty familar with it. But this has got me
stumped. Can you help?
Thanks...Ed
"Michael Aivaliotis" wrote in message
news:5065000000050000004F4D0000-1004225886000@exchange.ni.com...
> I've used Installshield Express to do this but I assume Installshield
> (IS) has this same functionality. You can tell IS to take the
> INSTALLDIR path from the registry. Specify:
> "HKEY_LOCAL_MACHINE\SOFTWARE\National
> Instrum
ents\LabVIEW\CurrentVersion\Path" as the registry entry for
> LV6.0. However, you should give the user the option of confirming this
> in case something goes wrong. I've been using IS Express for several
> months to install LV drivers and LV applications so if you need more
> info let me know...
