What is different between classes and type def?
When I use my classes, other Vis change properties of class when I change they in a class. The type definitions do the same. So what is diferent?
(3,529 Views)
Hi Forest, you have observed that classes are basically a fancy typedef cluster, but there are some other implications. With a class, you can inherit from other classes, not so with typedefs. Also with a class, the data is private, and can only be accessed by VIs within the class. A typedef (with public scope) can be accessed from anywhere.
This is just a quick answer, you can find many-paragraph articles on LabVIEW object oriented programming which will give you more info.
(3,504 Views)
Dynamic Dispatching
Dynamic Class instaciation
Support for class definition chages
Fancy wires
the opportunity to use the word "La-Voop" in every other sentence.
Ben
(3,484 Views)
It's also worth noting that in classes, the default values are part of the definition of the class where for a type definition they are not.
That means that if you put a class constant on a block diagram and update the defaults you'll be updating the constant, but if you put a type definition constant down on a block diagram and update the default values of the typedef, all of your existing code won't have the new defaults but if you add a new one somewhere it will.
(3,479 Views)
