Web Service HTTP Host Image
Hello Fellow LabVIEW Enthusiasts!
I am trying to host images on a Web Service through LabVIEW. My goal is to be able to change the images programmatically. I attached the project (zipped). When I try to "Publish" the service, it says that the "new picture" in HTTP_Picture is unsupported data type. I couldn't find any examples on this topic.
Also, I tried the NI Web Publishing Tool... this tool works great on Windows machines, however, I cannot load the images on my Android device, the plugin is unsupported. This is the reason I moved to the HTTP Web Services route. Any help would be greatly appreciated.
Thank you,
Nick
CLD Certified 2014
Message 1 of 13
(5,867 Views)
Hello Nick,
It looks like you folled the procedure outlined under heading 15 of this document: https://www.ni.com/en/support/documentation/supplemental/08/labview-web-services-faq.html#section--1...
Before I get to heavily involved in this I am curious if the images will all be available at build time or if you want to make new images available on the web that were not available at build time.  I think I would take different aproaches in the two scenerios.
- John
Message 2 of 13
(5,801 Views)
Hi John,
Thank you for your reply. I did follow many of the tutorials including the steps in the link that you referenced.
All of the pictures are known at build time. I am wondering if it is possible to have the HTML file of the web publishing tool accept LabVIEW commands to change pictures. I am still looking into other options, like you said there are many approaches possible to take. If I could find one that I know would work for my application, I would be able to focus and learn how to achomplish the task.
CLD Certified 2014
Message 3 of 13
(5,793 Views)
Nick,
I think you will have to do some sort of scripting.  Since you know all the images a build time I suggest you add them all as static images.  You can then use ESP or JAVA to change which static images (web pages) are visible.
https://forums.ni.com/t5/Example-Code/Scripting-in-LabVIEW-Web-Services/ta-p/3996297
are your images going to change when the user clicks on something? or will they change when some event happens on the host?
- John
Message 4 of 13
(5,764 Views)
I want LabVIEW to change which image is displayed on the webpage.
CLD Certified 2014
Message 5 of 13
(5,760 Views)
So you want something server side to change the image visible.  correct me if that is wrong.
What I imagine at this point is a a bunch of static pages that are all images.  Your startup VI can determine which image is available at any time.  Client side I think you will write some script that asks the page to update every minute or so.
As I understand it now there will be no user interactionw with the page.  The user will be purely a consumer.
Message 6 of 13
(5,753 Views)
Correct. I need a Java script (from an Android App) to change the visible image, however, it would be nicer if it were dynamic. I could then overlay text on the images.
CLD Certified 2014
Message 7 of 13
(5,749 Views)
I beleive some HTTP request needs to be made of the server in order to update the image.
Are the images always shown in the same sequence?
Message 8 of 13
(5,722 Views)
Yes, the pictures should be updated in a certain order. I am thinking that I need to send HTTP requests from the server to the client, the client will then refresh the page. Does this make sense or is there a better option?
CLD Certified 2014
Message 9 of 13
(5,701 Views)
Could you try using a gif?
Message 10 of 13
(5,679 Views)
