append data to top of text file
How can I go about appending data to the top of the file instead of the bottom as the attached VI does?
hiNI.
(5,100 Views)
Accepted by topic author hiNI
Read the whole file, set the file position offset to 0, then write the data with the new data at the top.
Jim
(5,089 Views)
Jim's solution is the proper way to do it.
but if the task is only this
(5,075 Views)
That just puts the new data at the end of the file, but backwards.
What did you mean by this?
Jim
(5,071 Views)
just for specific example.Smiley Happy( pun intended )
Solution is of course what you have given..........
(5,065 Views)
I am having a problem with the second line and beyond...there seems to be an extra tab.  How do I go about getting rid of the first tab from the second line and after?
hiNi.
(5,034 Views)
Your strings already have the End Of Line on them.  You do not want to use the Spreadsheet String To Array.  Wire your array straight into the Concatinate String.
(5,026 Views)
