Watlow F4T
I installed the driver from the exe on a win 7 machine and had no issues with 2011 or 2014.  I do not have a F4 connected, but I was able to run the included Vi's.
Message 11 of 18
(2,572 Views)
I have windows 10. Dint know that is the issue but i will try it on a win 7 see if i gey better results
Message 12 of 18
(2,570 Views)
Update,
i have installed this driver on a win 7 machine and it works flawless. On windows 10 I have the issue as described. has anyone solved this in windows 10?
Message 13 of 18
(2,555 Views)
Look into compatibility mode for Win 10, it might help.
Message 14 of 18
(2,545 Views)
Bryan,
a noob question... do i uninstall and reinstall under win 7 capability?
Message 15 of 18
(2,542 Views)
Accepted by fmeraz
Check out this article.
https://www.laptopmag.com/articles/set-compatibility-mode-windows-10
I would hope Watlow would be aware of this and have more info about compatibility issues.
Message 16 of 18
(2,538 Views)
Thank you Bryan. this worked... awesome now i need to start writing code...
Message 17 of 18
(2,533 Views)
Good to hear you are up and running.  Now the fun can begin!
Message 18 of 18
(2,523 Views)
