Water Controller using NI LabVIEW.
The Water Controller is built and equipped with a Tank which stores the water and Water level in it increases and decreases with respect to Inflow and Outflow inputs. Terminal strips are provided for I/O connections. The objective of the project is for students to design the software (using Lab VIEW) for the simulated Water controller such that it mimics the operation of a typical Water Controller.
This project provides a detailed listing of the requirements for the system and the functional test procedure for verifying proper operation of the system. This project has been found to effectively integrate software design, while utilizing information covered from many prerequisite courses.
(2,595 Views)
Soooo.... what is your question?
(2,579 Views)
Thanks, but I don't need a School Assignment -- I've already "taken the course".  I recommend that you do your own homework (feel free to ask your Instructor for help on concepts that you don't understand, and to use the Learning resources mentioned on the first page of this Forum).
(2,558 Views)
