Create a specific number of PWM pulses to control a motor using myRIO
I am trying to control a stepper motor and need to be able to generate a specific number of PWM pulses so i can control exactly how many steps the motor is taking. I have attached a picture of the code I am currently using. I can control the speed of the motor with this code but not the number of steps.
I'm fairly sure there is an easy way to do this but I am very new to Labview and struggling a little.
Any help would be hugely appreciated!
Rory
(2,608 Views)
Hey RoryM,
There's a tutorial at Pulse Width Modulation (PWM) Using NI-DAQmx and LabVIEW that's probably your best starting point.
Otherwise, have you checked out the LabVIEW forums and community examples for similar applications?
Generate a Software Timed Pulse Train Using a Digital Output
PWM labview using NI USB 6251 - suggest using a Digital channel, depending on how quick you need changes?
Update Digital Pulses from Multiple Counter Output Channels On The Fly is a more common approach with counters.
Let us know how you get on.
Rebecca
(2,569 Views)
