Voice recognition in labview
Thankyou so much for your kind reply sir......I tried comparing the array of waveforms by using auto indexing loop and successfully found the results.... thank you sooo much sirr....Smiley HappySmiley HappySmiley Happy
Message 11 of 31
(3,298 Views)
I have done comparing waveforms  in normal labVIEW.It had sound options and the code ran without any error.But when I opened the same code in LabVIEW myRIO ,SubVI not supported in current target occurs.Please help me as soon as possible   Smiley IndifferentSmiley IndifferentSmiley Indifferent
Message 12 of 31
(3,281 Views)
Hi riah,
Those sound file functions aren't supported on RT targets like your myRIO.
Which help do you expect?
Either convert your wave files to "raw" data file and use ReadBinaryFile function - or write your own function to read WAVE files on the myRIO…
Message 13 of 31
(3,275 Views)
There's absolutely no way that comparing two waveforms to see if they're exactly identical is going to work in practice. Even if you used the same recording for both the reference and the input command, any slight change in amplitude, added noise, or phase offset is going to make the two waveforms different.
Message 14 of 31
(3,266 Views)
Thankyou for your kind reply sir.... I will work on it Smiley Happy
Message 15 of 31
(3,255 Views)
I am also facing the same problem..... I am doing a project in Voice controlled wheelchair.I implemented comparing of waveforms in normal LabVIEW and when I tried to implement in MyRIO,an error occurs stating,
"The SubVI is not supported in the current target".
Does this mean that the sound input files can never be used in myRIO or the software is not installed propoerly... Please help me with this
Message 16 of 31
(3,257 Views)
Hi riah,
Yes: those functions are not supported on (my)RIO!
No.
Message 17 of 31
(3,254 Views)
Is there any alternate way to use sound input files in LabVIEW myRIOSmiley IndifferentSmiley Sad
Message 18 of 31
(3,252 Views)
Hi riah,
I already suggested alternatives yesterday…
Message 19 of 31
(3,249 Views)
Sir,
Is it possible to interface voice recognition module in myRIO...........
Message 20 of 31
(3,242 Views)
