Voice recognition in labview
Hy Everyone
I am new to labview. My project consists of voice recognition elevator system. my first task is to go ahead with voice recognition. I really need help. Smiley Sad
kunal
Message 1 of 20
(17,113 Views)
Hello!
What exactly does "voice recognition" means? Does system have to recognize the orders from user, or does it need to recognize the user?
Message 2 of 20
(17,109 Views)
Ahh the system have to recognize the orders from user. For example if someone calls the lift by saying "1" the lift should go to level one. It should recognize from any user.
Message 3 of 20
(17,084 Views)
Accepted by KunalNayak2015
There are two ways of achieving voice recognition in LabVIEW... One way is to use the existing Microsoft Speech API to acquire sound and generate text to compare the text with the string input. The other way is to acquire sound within LabVIEW, do some signal processing to generate spectral components and store them within a dictionary matrix, and then match the input signal with the stored signal to actuate an output.
*Thanks in kudos ^^*
Message 4 of 20
(17,072 Views)
Can I have some sort of block diagrams to work with. I have been searching and doing some work but it doesnt end up anywhere. A similar example orsomething. 😞
Message 5 of 20
(17,060 Views)
these links might help  you out
https://www.mediafire.com/?d9vidbj4ll9l5
https://decibel.ni.com/content/docs/DOC-36514
https://forums.ni.com/t5/Example-Code/Using-LabVIEW-for-Voice-Signal-Analysis/ta-p/3996192
Message 6 of 20
(17,055 Views)
Okay I will try to work on this.
Message 7 of 20
(17,053 Views)
Hey can anyone give a similar example or a bit soloution where I can work on.
Message 8 of 20
(16,950 Views)
Besides the middle link above, do a search for 'LabVIEW Speak'.
Message 9 of 20
(16,918 Views)
Okay I did come up with something like this. Please see if this correct.
Message 10 of 20
(16,846 Views)
