Vision assistant in LabView
This is exactly what I had, and actually, I just had to change one thing for it to run, taht s to say, link IMAQ ColorValueToInteger to IMAQ Create, and then I could run the operations, although surprisingly enough, I get the exact same front panel as before doing all that. I mean there are litteraly no difference in the image, the value... do you have to do something after to make all these tools installed activate or something? 🙂
Message 21 of 24
(629 Views)
this is literally my last update, and it just gives me the following front panel...
Message 22 of 24
(623 Views)
Hi Xavier,
Unfortunately the front panel on this VI is quite messy, you'll find that there are indicators at the top left, and the bottom right of the front panel that you have to use the scroll bars to find, your best bet is to move them all into one area on your block diagram. If you double click elements on your block diagram you can locate them on your front panel and vice versa.
Mark W
National Instruments UK & Ireland
Message 23 of 24
(617 Views)
Dear Mark,
Thanks so much, I can now confirm that I have acheived what I was looking for, even so, the tool I used from Vision Assistant was just an expample and not the actual task I wanted to make it achieve, but now |I know it s feasable, and from what you have shown me, I think I can link any vision assistant converted to VIs 🙂
Once again, thank you very much.
have a pleasant day
Best regards
Xavier Baines
Message 24 of 24
(608 Views)
