How I can send serial NI cFP-2220 output to RTU IEC 60870-5-101 ?
I have to send my calculated data to remote SCADA via RTU which work on  IEC 60870-5-101.
Does anybody have experience how I can send it via my serial port on NI cFP-2220?
Mujo
Message 1 of 9
(4,007 Views)
Hi Mujo,
I don't know of any current examples or drivers for the IEC 60870-5-101 protocol. However, I did some research and NI is preparing a new driver for the IEC 60870-5-101 protocol that should be available as a beta later in the spring.
If you need something in the meantime, you may need to roll your own.
Hope this helps,
Fred Visser -- SystemLink R&D -- National Instruments
Message 2 of 9
(3,982 Views)
Thank you for answer but can you tell me more precisely when it will be. We finished whole application and only need this possibility. Customers need some information about time.
Mujo
Message 3 of 9
(3,943 Views)
Hi Muju,
The driver is still in development, but is currently scheduled to be in beta in May.
I hope this helps,
Message 4 of 9
(3,920 Views)
Hi Fred!
Any updates on this driver development?
My customer needs support for IEC -60870-5-104
Ankur.
Message 5 of 9
(3,793 Views)
The driver for IEC-60870-5-101 and -104 is now available.  The PN is 781647-01 and the details will be available on ni.com soon.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
Message 6 of 9
(3,758 Views)
Does any budy know how to Use the function which comes under IEC 60870-5 104.
i found a image at below site
 http://sine.ni.com/nips/cds/view/p/lang/en/nid/210149
But it is only a write function .
I would like to know how to Read.
if you any budy have a example pls share.
Regards
Sandeep
Message 7 of 9
(3,633 Views)
Hi Sandeep,
This thread hasn't been posted on in over a year, you may want to start a new thread on this subject since newer threads tend to get more attention.
Message 8 of 9
(3,621 Views)
ok
thanks for suggestion
Sandeep
Message 9 of 9
(3,611 Views)
