Vision acquisition software installed but missing
I wanted to embed the front panel of my VI in the image captured by my webcam. I read that I should install NI Vision Acquisition Software and that's what I did for the latest version although I have 2022 Q3 Labview because I used it in my MSc in 2022. It seems that the Vision and motion functions are missing. I have only IMAQ session in controls. I tried to install it again but for 2022 Q3 version and package manager said "nothing to be performed". Is there any possibility to make it or as having student license it's impossible?
Thanks.
(2,354 Views)
The Vision Acquisition Software (VAS) and Vision Development Module (VDM) are both included with the Academic License.  I don't recall if either is included in the Professional License, otherwise they each have separate licenses.  You need the VDM to manipulate images and the VAS to acquire them from cameras.
You may have "installed, but unlicensed" software.  You can open the NI License Manager to check this out.
(2,339 Views)
No, the absence of the license will not remove Vision from the Palette, instead of that attempt to call any function with missing license will return license error.
In general its a common "issue" if LabVIEW was installed after Vision, then attempt to install already installed Vision to add Vision Support to LabVIEW where it missed will give an "error" nothing to be performed.
It is necessary to uninstall (Remove) Vision before re-installation:
After installation the support will be added to all supported LabVIEW versions:
(2,323 Views)
No, Labview was installed more than a year ago. Vision was today. Do I still need to uninstall something? Maybe the problem is that I used the same serial number to activate the package as a previous time I installed another package a few months ago?
(2,281 Views)
It's licensed. What can I do?
(2,279 Views)
Accepted by topic author Bob_Schor
You are missing the Vision Development Module.
(2,254 Views)
Accepted by bitsandscience
Ok, I thought for my application I only needed the first one. I'll install the other one and tell you if it works 😉
Thanks!
(2,232 Views)
