NEED HELP
I made a LabVIEW program to display analog input voltage values and it worked fine but now it displays wrong values. i even checked the MAX test and it showed correct voltage values .i even checked the hardware connection it turned out to be right. HELP me solve this problem.it is very URGENT!!!!!!!!!!!
(734 Views)
Hi there, please read the link below about guidelines for asking good questions on the forum. It will help you get much better answers to your questions.
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
(726 Views)
If you attach your VI, people can attempt to debug the program
(615 Views)
