VisaWRITE to Arduino
Hello everyone,
I am about 3 weeks new to LabVIEW and having troubles with a bit of information.
I want to send commands from the LabVIEW interface to my Arduino.
The idea is that by changing the intensities of RGB i can address the information to the microcontroller and output the PWM signal to each device
Already i am passing information from the Arduino into my Labview Interface.
i have attached the 2017 version of LabVIEW for your feedback and a picture of the section i want to send to my Arduino
Please help 🙂
(2,851 Views)
Hi XX,
you need to create a message (a string) to send it to your Arduino ( as I mentioned before).
And you need to create a sketch for the Arduino which is able to process that message...
(2,826 Views)
Yes but still stringing it all together what blocks do i use?
(2,822 Views)
You use the blocks you need to use.
Were you expecting someone to write both the LabVIEW and the C/C++ Arduino code?
For the Arduino to control RGB LEDs, there are libraries.
or
You can do it the hard way.
Tutorial for the Arduino portion: https://learn.adafruit.com/adafruit-arduino-lesson-3-rgb-leds/arduino-sketch#
It boils down to establishing good serial communication with the Arduino.
Adding LabVIEW to the equation adds more complexity.
Everything can be done without the need of LabVIEW.
(2,818 Views)
