03-24-2006 04:49 PM
03-27-2006 03:59 PM
03-27-2006 07:06 PM
03-28-2006 05:55 AM - edited 03-28-2006 05:55 AM
The alias names are stored in the visaconf.ini (on my PC located at C:\VXIPNP\WinNT\NIvisa) just have a look inside.
Section [ALIASES]
It should be possible to use the vis to handle ini-files for your changes. You might need a reboot.
I'm not shure if that is a recommended way of changing the alias, however we did that for the same propose, but the changes were done by our netinstaller without NI software running and it worked fine.
And don't forget to correct the key: NumAliases
Message Edited by Henrik Volkers on 03-28-2006 12:57 PM
03-28-2006 11:08 AM - edited 03-28-2006 11:08 AM
Message Edited by Iñaki on 03-28-2006 10:09 AM
