Virtual Channel error
I am attempting to create a simple virtual channel in MAX to generate a digital output. I keep getting a timing error but I can't find the source of the error. I am sure there is a simple fix but I'm a novice and can't figure it out on my own. I'd appreciate any help you can offer.
Thanks.
The error:
Error -200077 occurred at DAQ Assistant
Possible Reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Sample Clock
You Can Select: On Demand
(2,433 Views)
Did you search for that error code or message? It is a common one.
Whatever hardware you have (and why did you not provide that essential information?), only supports software timed I/O. You simply cannot use any timing function.
(2,428 Views)
Figured it out. Thanks for the help and the sass!
(2,421 Views)
