‎08-12-2008 07:25 AM
I’m wondering if anyone might know how to change the orientation of a text box so that it would display vertically?
Currently using LabView 8.2
Thx-
-Peter
‎08-12-2008 07:41 AM
‎08-12-2008 07:50 AM
Christian!
You were so close to the mark! ![]()
The "Text Orientation" input of the "Draw Text in Rectangle" allows you to specify the orientation.
(I can hear it coming) Yes your solution will also let you present text oriented at a 45 degree angle. ![]()
Ben
‎08-12-2008 08:04 AM
‎08-12-2008 08:40 AM
‎08-12-2008 10:09 AM
Am I the only one who thinks this is rarely a good idea?
If you have to rotate a piece of text because of space issues then it probably means that you need to rethink your GUI.
(Of course, there are also valid reasons for doing this, but they are relatively rare).
‎08-12-2008 10:40 AM
‎08-12-2008 10:45 AM
Hi All-
Thx for the quick feedback on this. I've now played with that VI and it's going to work for me after some changes. It'll take some planning, but I'll get there.
The reason for doing this is it's a dynamic front panel that'll display boxes based on some criteria and as more things get displayed the text will need to go vertical to accommodate all visable boxes.
-Peter
‎08-12-2008 11:10 AM
‎08-12-2008 12:35 PM
