Values Radio button
Hello, I am trying to sum the values of the same elements in my table but I have this error.
I don't understand this error, can you help me please?
(Sorry I had forget the image in the first post)
Message 11 of 16
(1,679 Views)
Hi Ngouda,
Did you try to check the inputs for ScanFromString using probes?
This way you can easily find the reason for that error…
Message 12 of 16
(1,666 Views)
Hi Gerdw,
Yes I tried the probe, I saw that it only takes commas as input and yet I have the values in the table that I use as input, but I still can't figure out why, I've tried many things but I'm still stuck on it.
Message 13 of 16
(1,648 Views)
Hi Ngouda,
I really don't know what you are talking about…
In your VI you initialize the shift register with an array of 10 empty strings.
In the timeout you try to parse that array, but ScanFromString fails because it cannot find the expected data in your array of empty strings!
Did you really use probes (and highlight execution) to find the problem?
Message 14 of 16
(1,621 Views)
Hi GrdW,
Yes ScanFromString failed because the array is not filled it is empty.
Yes I did the probe.
Now how to make ScanFromString act only when the array is filled please?
Message 15 of 16
(1,605 Views)
Hi Ngouda,
IF array element is filled
THEN ScanFromString
Or implement some error handling to act appropriately upon that error…
Message 16 of 16
(1,598 Views)
