Value signaling executing several times in EXE
I have a value signaling on a boolean indicator at the begining of my code to trigger an init event in my thread.
It's working as usual in developpement system but when running in EXE, my value signaling is triggering the event several times (3).
I use Labview 2017 SP1.
Where does this come from ?
Margaux
(2,659 Views)
Hi Margaux,
I guess the problem is in your code.
But there is no code attached to your message…
(2,655 Views)
It's only showing when I debug the EXE (Menu -> Operate)
(2,650 Views)
Hi Y,
Just from running the EXE I cannot see the problem…
So the problem seems to be related to debugging the EXE!?
Maybe the debugging restarts the EXE in an uncommon way? (And what is the resulting problem from this behaviour?)
(2,642 Views)
Strange. I just built it with debugging enabled and wait on launch. The init case runs three times when debugging. Just running from the exe works as expected (1 time). I too would like to understand what happens. The debugging is firing some extra events?
Certified LabVIEW Architect
(2,641 Views)
Put a one-button dialog in that event and add indicators for "source" and "Type".
Not that I know what is happening but I am a curious animal.
Ben
(2,613 Views)
