Hi there,
I'm using LabVIEW 2013 on Windows 7.
I've a problem with a LabVIEW project. I've created a I/O server (type OPC client) in the project explorer. I make the code and I run the simulation. Sometimes it works and sometimes doesn't works.
When it doesn't works, if I browse to look for the variable I have to read, I even didn't see the variables.
I also open the "NI Distributed System Manager" and also with this tool I can't see the variables and it says that the connection was cutted. So that if I run the simulation, LabVIEW give me the error -1950679035 (image attached), because it can't reach the variable.
Someone has a solution? Someone already had this problem?
Thank you very much
