VISA and error message display
HI..
I'm using VISA config in d beginning of my VI. I have set VISA resource name as COM3. I want to popup a message if COM3 doesn't exist in my computer. how can i implement that...???
Thank you...
(2,606 Views)
The is a function called VISA Find Resources (from memory, I don't have LV on this PC). The output of the function is a string array of the resources found. You can search this array for a COM3 port using the Search 1D Array function followed by a case structure containing the popup in the case COM3 is not found (find index = -1).
Ben64
(2,603 Views)
