VISA TCP/IP Check if Connected
I have a TCP/IP resource that I'm communicating with via VISA. It works just fine, but I'm trying to check the connection periodically to make sure everything is still functional. The "Is Connected" property works for serial communication, but it outputs False every time with this TCP/IP connection. Does anybody know a quick way of checking the connection? Do I need to ping the IP Address?
See attached snippet to see how I initialize the connection for clarity.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(5,073 Views)
Accepted by topic author James.M
Hi james,
did you consider sending periodically a status request to your device?
The overhead most probably would be negligible and it lets you check non only the presence over the network of the device but also its overall status.
Marco
(5,024 Views)
Hi James,
I'd like to add that this is not a VISA-related problem.
I'd suggest this good reading:
http://www.codeproject.com/Articles/37490/Detection-of-Half-Open-Dropped-TCP-IP-Socket-Conne
Marco
(5,017 Views)
MarcoMauri,
Thanks for the tip. I think that a request to the device every once in a while is really the only way to check I guess. That article clears up why I'm seeing what I'm seeing. Thanks!
Cheers
(4,977 Views)
