cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
VISA Resource name Select
Resolvido!
Ir para a solução
Hi all,
I have a visa resource name select in my program that would allow me to select my GPIB channel.  When I click on the down arrow to select, it takes a long time (about 6s) for the options to show up.  Yes, some of the options are remote resources.  Is there a way to make the visa resource name select drop down box more responsive?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
Mensagem 1 de 9
5.742Exibições
I dunno - speed up the network?  If the resources you are interested in never change, maybe you can hardcode some constants and select from them instead?
Bill
CLD
(Mid-Level minion.)
Mensagem 2 de 9
5.723Exibições
Maybe there are some setting in MAX that I can modify?
Yik
Mensagem 3 de 9
5.690Exibições
The list can only populate as quickly as it can locate all of the resources, so as billko said, your bottleneck here is your network speed.
Well, probably not the speed of the network itself, but how quickly the resources respond to pings or whatever protocol is used to check their availability.
It is not anything in MAX that is slowing you down, it is how quickly the network resources are being located.
Cory K
Mensagem 4 de 9
5.681Exibições
Solução
Aceita por jyang72211
Use visa find resources at the start of your program. That should work.
Edit: I said should work - let me know if it in fact does work!
LabVIEW 2012
Mensagem 5 de 9
5.670Exibições
Technically it doesn't speed things up, but moves the delay somewhere not so annoying.  It's a good compromise!
Bill
CLD
(Mid-Level minion.)
Mensagem 6 de 9
5.651Exibições
Nice!  Thanks!
Mensagem 7 de 9
5.639Exibições
hi im new in labview.. can ask some question regarding is using visa serial..
about the resoure name..does it automaticaly show the ports when i click the combo box?
or i just set up 1st or maybe type the name of the port? only refresh come.up..
Mensagem 8 de 9
5.495Exibições
If you place a Open Visa connection and Create Control it'll automatically scan, yes. You'll see the ones found/visible in MAX.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Mensagem 9 de 9
5.483Exibições
