NI-DAQmx with Windows7
What is the oldest version of Measurement and Automation Explorer that can be used with Windows7 32 bit?  My USB-6009 is seen by windows device manager, but MAX 8.6 won't recognize it.  Do I need a later version?
(3,560 Views)
MAX comes with NI-DAQ.  There is no MAX 8.6, you must mean the DAQ version.  Check these charts for compatibilities:
https://www.ni.com/en/support/documentation/compatibility/16/measurement---automation-explorer--max-...
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,550 Views)
Thank you for the charts, however I still need to know if this version of Max (4.3) and DAQmx (8.6) will work on Windows7 32bit.  I'm having no luck recognizing my DAQ.  I'm not even seeing it as a DAQmx device in "Devices and Interfaces"
(3,533 Views)
(3,525 Views)
Accepted by topic author Dan@Parker
In this post, Adnan (CLA) says you need to use DAQmx 9.0.2.  Have you tried that, or just the latest version?
(3,517 Views)
