VI's bogging down?
Ok guys/gals, quick question.... when creating a subVI... When I highlight a section of code that I want to create the sub from, if there are shift registers going in and coming out will those be pulled into the subVI or will they create inputs & outputs on my icon?
THX
C
Message 31 of 53
(1,499 Views)
THX
C
Sooner or latter you will know sooooo much about LV that asking us will not help. In that case you will have to do what the rest of us do and that is...
Backup all of your code.
Back it up again (in case you are unsure).
Then try it out for yourself.
In your case I think you will find that LV will create input and outputs for the wires.
Have fun!
Ben
Message 32 of 53
(1,492 Views)
Ben
On-The-Job training recomendation from Ben!   Smiley Surprised
But valuable advice- Try it out- if it doesn't work go to the backup and try something else
"Should be" isn't "Is" -Jay
Message 33 of 53
(1,486 Views)
Yeah, ok... I'm trying to cheat... ..er, no that's "using all reasources available"... not cheating!  Smiley Very Happy
I figure it'll blow up, but yeah... here goes nothing.
Message 34 of 53
(1,479 Views)
Ok... yeah, that didn't go as planned.  Smiley Indifferent  ...on to plan B.
Message 35 of 53
(1,473 Views)
Don't save the changes unless that is what you wanted to have... Otherwise, there is no turning back..  Unless of course you have backed up (zipped, saved on another drive, etc) first.
Message 36 of 53
(1,471 Views)
Gotcha...  I'm playing with a copy.
THX
C
Message 37 of 53
(1,461 Views)
It's always a good idea to backup development software on a regular basis (ie once a day) 😉
Message 38 of 53
(1,451 Views)
True, but it's an even better idea to use Source Code Control to handle your backups.  (For a single developer, even setting up a local SVN with tortoise does wonders)
Message 39 of 53
(1,445 Views)
I've learned that lesson the hard way... I save several times a day, and each day gets a final save at the end of the day with it's own date code.  The next time I work on a particular project I just rev up the date.  Losing a few hours of work is not nearly as frustrating as several days of work! Smiley Wink
C
Message 40 of 53
(1,444 Views)
