Security system
Will anyone please go through my security system solution
Just started my preparation for CLD, initially lets ignore documentation and style
I just want to know is this kind of programming is OK
Thank you
(2,927 Views)
Hey,
Please see the following as some hints Smiley Wink
- Use a Statemachine Framework with an Initialize and Shutdown state instead of a Sequence Frame.
- The Event Structure then can be placed in a kind of "Running" state.
- As far as I know the Controls/Indicators should be part of Clusters. Save them as Typedefs.
- Create Documentation and Tip Strip immediately when you place a Control/Indicator on the FP
- Use the 4224 Connector Pane Pattern for your SubVI.
- Place Controls/Indicators into the Event Frame which handles them
- Do the Initalization of the Controls in a SubVI by pasing their References
- Create FGV for FileIO which you call in the Init state for creating the header and in the Running State for saving the data
Good luck for the CLD Exam!
Christian
(2,912 Views)
I understood that I need to improve a lot and should not do any crude programming
Thanks a lot for the suggestions
(2,890 Views)
Also, don't discount documentation and style, they are very large parts of the grading.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,869 Views)
