VI does not open anymore
I have been working on a VI for a few Months not and it does not open anymore. The last change I did was on a Mixed signal graph
and now when I try to open the VI LabVIEW freezes at the welcome screen. Any ideas on how to recover this VI will save tons of work.
Message 1 of 26
(6,588 Views)
What message does it give you when you try to open it?
Do you get an error code or message?
Do you have a recent backup of that vi?
Message 2 of 26
(6,580 Views)
No error messages or Error codes. The welcome screen freezes and then I have to just kill labView from the windows task manager.
Unfortunately there were no recent back ups, The last back up was done in June. very frustrating.
Message 3 of 26
(6,575 Views)
If you don't have a back-up there is one possiblity...
My Documents\LabVIEW Data\LVAutoSave
may have something for you.
Otherwise....
Ben
Message 4 of 26
(6,571 Views)
The vi may be in run-on-open mode.  You might try creating a new blank vi and adding the vi to the block diagram and try opening it up from there.
Good Luck.
Message 5 of 26
(6,567 Views)
BEFORE using the one Ben suggested, make an extra copy... just in case.
Always backup your code.  On a daily basis if possible.  Look at using a Source Control application.  For single users, there are some 'free' versions that you can download.
Message 6 of 26
(6,561 Views)
Good Luck.
Why would that freeze LabVIEW when being opened?
Message 7 of 26
(6,559 Views)
Nothing in the AutoSave folder!!.. What a bad day.. I have been reset by 2 months. No error messages, No ways to recover, Labview just freezes when opening this file, I tried to place it in a blank VI that does not help either.
Message 8 of 26
(6,552 Views)
As a shot in the dark...
try opening the VI in a text editor like Notepad to see if a data file got saved over teh VI.
Ben
Message 9 of 26
(6,527 Views)
I could not make out if there was a data file overwrite by looking at it in notepad. Would you like to help I have attached the file.
This VI referes many sub VIs so you might not be able to open it in LabVIEW.
Message 10 of 26
(6,519 Views)
