Error -89130 occured at DAQmx Start Task.vi:1
Dear Forum users,
I am using NI PXI-1050. And the data acquisition is through Labview, using the attached vibe.vi file (included into the attached zip file).
When I clicked the "start" button, I got the following error message,
Possible reason(s):
Device not available for routing.  It is possible that the device needs to be reset or that the device is being reset.
If you are resetting the device, wait for the reset to complete.
For example, if you have used the device through Traditional NI-DAQ, you must reset the device before the requested route can be made.  For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ.
Task Name: _unnamedTask<0>
Since recently we had our NI instrument returned from a service center and possibily they used for their data acquisition Traditional NI-DAQ (Legacy) instead of NI-DAQmx, which we have been using. Therefore our original vibe.vi file needs to be reset. (https://www.ni.com/en/support/documentation/supplemental/06/answers-to-frequently-asked-questions-ab... for faq: Q.) Do you have any idea about how to add an reset block into the block diagram? I attached to you our vi file for an easy reference. Thank you!
Leqia He
(4,268 Views)
(4,236 Views)
I have tried to reset NI-DAQmx configuration under Measurement and Automation explorer, as suggested on https://www.ni.com/en/support/documentation/supplemental/06/answers-to-frequently-asked-questions-ab... (see Q) NI-DAQmx needs to be reset for this kind of problems.
We used to have a NI-DAQmx task named "NI PXI-4472B modules" under the Data Neighbourhood. After resetting, I wanted to create a new NI-DAQmx. But when I reached the steps after select "create new NI-DAQmx task" - "Analog input" and "Accelerations", I saw a empty panel written "No Supported Device found".
Then following your suggestion, under the "device manager" of windows, I reinstalled that the PCI-1510 cardbus controller. But the problem is not solved. Moreover, I can't find the way to reset my device under "Devices and Interfaces". There is no "reset your device " by right click the device.
(4,225 Views)
also please refer to the attached photo22685iCA5AB31574E23735
(4,222 Views)
