VI analyzer: Wire under object test fails with Call Library Function Nodes
If I wire a Call Library Function Node with an ErrorIn and an ErrorOut, the VI Analyzer Test "Wire under Object" fails always with two occurrences per Call Library Function Node.
A double click to the occurrence highlights the error lines connected with the call... node.
The test does not fail, if the error lines are not connected.
Thanks!
H
(3,240 Views)
Hello Johann,
I could confirm this bug and reopened CAR #102702.
Thank you for the information.
Best regards
Michael
National  Instruments
Technical Support
(3,214 Views)
Forget the no. above, I filed a new Corrective Action Request.
regards Michael
(3,207 Views)
regards Michael
And the new number is.....?
Ben
(3,204 Views)
Accepted by Johann_Hasiba
Sorry, the number of the created CAR is #208992.
Kind regards
Michael
(3,202 Views)
This became a problem when Call Library Nodes got error terminals (and optional path terminals) in LabVIEW 8.20.  I should be able to get a fix in to VI Analyzer Toolkit 2010.
Thanks for taking the time to report the bug.
(3,185 Views)
