取消
显示结果
搜索替代
您的意思是:
VHDL Code for CLIP Clocks (FPGA Module)
Hi to all,
I'm trying to use the Configure Component-Level IP wizard to create the declaration XML file automatically from the vhdl.
I'm following the procedure on http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahelp/fpga_clip_clock_ex_code/
when I try to do "check syntax" in step 3 of 9 I always get the following error:
Compiling architecture rtl of entity xil_defaultlib.clipgenerateclks [clipgenerateclks]
gcc.exe: Internal error: Aborted (program collect2)
Please submit a full bug report.
See <URL:http://www.mingw.org/bugs.shtml> for instructions.
Fix the above error and check syntax again.
Can someone help me?
Thanks in advance.
Giovanni Maio
0 项奖励
1 条消息(共 5 条)
4,613 次查看
0 项奖励
2 条消息(共 5 条)
4,593 次查看
Thanks for the reply.
I followed the steps recommended by you, but now I get the following new error:
ERROR: [XSIM 43-3409] Failed to compile generated C file xsim.dir/ClipGenerateClks/obj/xsim_0.c.
ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
do you have any idea?
Thanks in advance.
Giovanni
0 项奖励
3 条消息(共 5 条)
4,567 次查看
A quick look at Xilinx forums shows two ways to fix this:
1. Upgrade Vivado tools to newer version (by the way, what LV FPGA / Vivado tools are you using? And what operating system?). That would mean upgrading LabVIEW. Also - check the links in this thread for more information about Vivado/Windows compatibility: https://forums.ni.com/t5/LabVIEW/LabVIEW-2015-Windows-10-Configure-Xilinx-IP-not-working/m-p/3668520...
2. Finding the source of the problem and fixing it, as described here: https://forums.xilinx.com/t5/Simulation-and-Verification/One-solution-to-error-quot-Failed-to-compil... or here: https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2017-2-Simulation-XSIM-43-3409-Faile... (note that both topics describe how to do it on Linux, so you have to port them to Windows if that's your case).
0 项奖励
4 条消息(共 5 条)
4,537 次查看
Good morning,
The software configuration of my system is as follows:
- Windows Server 2012 R2, but I run Labview in compatibility mode (Windows 😎
- NI Labview 15.0.0 (32 bit)
- Vivado 2014.4
- Xilinx 14.7
- gcc version 8.1.0 (i686-posix-dwarf-rev0, Built by MinGW-W64 project)
1. Compatibility is there;
2. In my system, "libtinfo" is not present.
Giovanni
0 项奖励
5 条消息(共 5 条)
4,528 次查看
