Using subVI as control?
@prettypwnie wrote:
And yeah, it's a functional global not a global variable.
In addition, "global" implies just that, so once the subVI is preallocate/reentrant, there is nothing "global" about it. Each subVI instance has it's own sandbox. (... which we want in this case, of course!)
Action engines and functional globals are typically non-reentrant so the data can be shared globally.
Semantics. 😄
Message 11 of 15
(1,323 Views)
Yeah, I tend to always say functional global when referring to an uninitialized shift register, but you're right, its a bit misleading to say it's "global" when it has pre-allocated reentrancy.
Message 12 of 15
(1,318 Views)
@altenbach wrote:
You can handle all possible state transitions by creating an array with four elements (the current boolean values and their previous value from a feedback node), converting it to a number (boolean array to number) and wiring the number to a case structure.
Here's a quick example. Notice that the logic is now MUCH simpler than yours. 😄
(please verify correct operation. It would be easy to implements the logic into a subVI using the references as mentioned already).
Message 13 of 15
(1,301 Views)
Accepted by RaymondLo
altenbach wrote:
It would be easy to implements the logic into a subVI using the references as mentioned already.
Here's an example for that.
Message 14 of 15
(1,295 Views)
@altenbach
Thanks! This does seem much nicer. I am sticking with what I had because it's working and it's a subVI so it doesn't really mess with the main BD, but this is definately a much nicer way to handle the boolean logic and I will keep an approach like this in mind next time I try and do some boolean binding.
Best,
Ray
Message 15 of 15
(1,260 Views)
