Using a wiimote with LabVIEW
Please find it on page 12, message posted by phreezer the 12.03.09 I use this one. Thanks
Message 181 of 220
(3,469 Views)
Hello CIML,
I looked at the sample project that was posted on page 12 and read some interesting information in that post .  It seems that the VI posted does not actually function like you might think:
"I was able to get sound to come out of the speaker but it sounds nothing like the source wave.  From what I could find from a bit of searching on the internet it didn't seem like there had been much success using the speaker for anything other than simple tones yet."
It appears that the encoding may not be correct for the Wii remote to use.  I would contact the uploader and find what input sound files were being used for his testing and check if he has had any more success.
Anthony F.
Staff Software Engineer
Message 182 of 220
(3,443 Views)
Hello everybody,
In order to drive a robot, I've written a VI which read values from the Wii Motion Plus.
I just want to share it with you, so here is the file.
Message 183 of 220
(3,322 Views)
Here is how it works:
Message 184 of 220
(3,320 Views)
Some updates:
-auto zero at wii motion plus initialization
-convertion from raw values to deg/s
-compatibility with Labview 8.6 (wiimote_old.zip)
Exemple:
Message 185 of 220
(3,310 Views)
I'm trying to use the lib with a Toshiba Bluetooth Stack. The "Wiimote Open" Sub-VI returns an "Ok" error message, but any other Suv-VI returns an "-1" error code. Does anybody knows how to fix it, except using the native windows stack?
Nico
Message 186 of 220
(3,217 Views)
Hello Balandier,
Personally, I gave up using Labview with Toshiba stack and I came back to Windows one. Since I did that, it works without too many problems...
Message 187 of 220
(3,196 Views)
Thank you for you fast answer. I tried to use the Toshiba satck because I thought it would help me to acquire signals from two wiimotes at the same time. I only succeded once with the Windows stack. I'll post a clean VI as soon as I can.
Regards
N. Balandier
Message 188 of 220
(3,171 Views)
Hello eveybody
Here is the VI I'm working on. When it runs, I can get the states of the buttons of both wiimotes, but one of the two graphs remains flat. Can someone help me?
N. Balandier
Message 189 of 220
(3,152 Views)
I have modified the C# wiimote library (by Brian Peek), added a better support for motion plus, read its calibration and a EKF - extended kalman filter- to calculate its position - just Pitch and roll - from Accel and Gyro. The actual library version is 1.9 - I  have hear Brain would release a 2.0 soon.
The labview sample uses this DLL ans show a 3D wiimote, the position, acell data and gyro.  The labview lib is a mix of the many libs found in this forum.
I have the C# source code if need.
Message 190 of 220
(3,068 Views)
