Using a wiimote with LabVIEW
No joy with new BT USB. Bought Zoom 4322 and still same old same old. Works with WiimoteTest.exe but LV code still produces error 1172.
Message 171 of 220
(2,919 Views)
Hi RAMaston,
I think the best place to ask this question would be on the existing Wiimote thread: Using a wiimote with LabVIEW.
Sanjay C.
Embedded Software Product Manager| National Instruments
Message 172 of 220
(2,900 Views)
Unless I'm missing something, this is that thread!Smiley Surprised
Message 173 of 220
(2,895 Views)
Can someone down convert this subBluetoothConnect.vi to LV 8.6 or lower?
Message 174 of 220
(2,797 Views)
If you don't mind, could you please post this request in the Downconvert VI Requests Forum?
Sanjay C.
Message 175 of 220
(2,772 Views)
Hi, I'm unable to play sound on the wiimote with the speaker. I've tried the example called wiimote test speaker.vi. There's no error but no sound is played! Or I hear anything. Thanks for your help.
Message 176 of 220
(2,376 Views)
Do all the other functions, buttons & rumble for example, work?
Message 177 of 220
(2,370 Views)
Yes. Everything works properly. Only the speaker does not work. Thanks
Message 178 of 220
(2,355 Views)
Is it possible that the vis or dll are out of date? Or a conflict with installed files? I will try that on another computer but if you have a solution... Thanks in advance
Message 179 of 220
(2,339 Views)
Can you post your test vi? I don't see a speaker option method in mine.
Message 180 of 220
(2,334 Views)
