Using LabVIEW to insert rows to Google Sheets
Is there currently a reliable LabVIEW library or method available for the use of dumping information to Google Sheets? I am trying to periodically update a spreadsheet using data that users generate from a test screen in one of my applications.
I have tried the approach (method #3) mentioned here, but am getting an HTML body returned that informs me Google is "unable to open the file at this time."
http://asee-ne.org/conferences/aseene/2018/index.php/aseene/aseene2018/paper/viewFile/321/204
I have seen some other threads but they seem to fizzle out into uncertainty regarding the results.
Thank you
(3,456 Views)
There's an API for .NET that you could theoretically use.
By getting the package and all its dependencies I was able to get the DLL to be readable in LabVIEW.  Since I went to the effort I went ahead and zipped up the file.
You might need to add a LabVIEW.exe.config file next to your EXE in Program Files to get them to work:
<?xml version ="1.0" encoding="utf-8" ?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
	<supportedRuntime version="v4.0.30319"/>
	<requiredRuntime version="v4.0.30319"/>
</startup>
<runtime>
	<loadFromRemoteSources enabled="true" />
</runtime>
</configuration>
However, beyond getting it to be loadable in LabVIEW, I didn't try anything else.  So I hope you like reading their documentation.
(3,431 Views)
