Interactive program for sensor and pump controls
I'm looking to start a project using several liquid pumps (3) and sensors (1 or 2) and need a bit of advice. I am trying to figure out what general program structure to use as an overall control. Is an event-based queued state machine overall with each pump/sensor having a subVI with the communication state machines a common approach or would there be a better way to do it?
Thanks for any help.
(2,456 Views)
Sensors are typically read, not controlled. How does everything mesh together? Are the pumps controlled manually by the user or automatically based on sensor readings? What's a typical update rate?
(2,410 Views)
