Using Event structure to open subvi
I am trying to create a project that requires many VI's to be opened. Therefore, I created my main menu panel, as well as a sub-VI called "User Input Panel."
I have inserted a while loop with an event structure, but when I press the boolean button related to the event structure, my sub-VI does not pop up. Can anyone help me with this?
(932 Views)
Accepted by Rusyaidi_arif_cute
If placed as a sub-vi you need to either set the VI property "open when called" or use an Invoke node:Front panel open
Qestit Systems
Certified-LabVIEW-Developer
(927 Views)
Thank you so much!. I have solved it in VI Properties->Window Apperance->Customize.
(904 Views)
