Preload custom probes for specific project
Hey guys,
so our team is developing a modular framework that is based of advanced AF with a lot of packed libs. In order to debug everything correctly and quickly I love to use custom probes that show the information for specific objects and actors the way I like it.
Now I have roughly 15 custom probes that are placed inside the LabVIEWData/probes folder.
When doing so I have two problems:
1. The context menu only seems to show the correct custom probe when this has already been loaded to memory
2. The first right click after launching the project now takes roughly 20..30 seconds until the context menu is finally opened. When removing the probes, it pops up in no time
So I was thinking about a solution for this and wondered if...
...anyone else has the same problem? (maybe I am doing something wrong here)
...there is a way to preload those probes already into memory when starting the project? (the project might need longer to load but maybe at least the context menu is then faster and showing the compatible probes)
Thanks already in advance!
Jenso
Message 1 of 1
(378 Views)
