Using Analog Video Generator
I want to use Analog Video Generator via Dynamic linked library.
First, I tested in labview 2017.
There is an error
C:\ProgramFiles (x86)\National Instruments\Analog Video Generator\bin\NI Analog Video Generator.dll\mxVideoGeneratorGet_I16_LineBlock.vi
Error code -6
I cant find meaning of the error code.
What does that mean?
Please use my sample project, if necessary.
I cant find error code
(3,108 Views)
Click ''help'' then choose ''explain error'' . Enter the error code ''-6'' , It will explain the meaning of error code.
(3,087 Views)
I already did
"This error code is undefined. An undefined error can occur for a variety of reasons. For example, you might not have a description of the code, or you might have linked a number that is not an error code to the error code input."
It is not helpful ..
(3,078 Views)
You should use LabVIEW 2012 - 32bit or less for Analog Video Generator as shown in Readme link below.
http://download.ni.com/support/softlib//Analog%20Video%20Generator/readme.txt
Analog Video Generator does not support LabVIEW 2017.
I have tested with LabVIEW 2017 but I also was not able to use any subVIs.
In addition, following is the Error -6 description you also mentioned before.
Incompatible LabVIEW version can be your case for this problem.
Error -6 occurred in: Unverified Location
In addition, there may be undefined errors when errors are related to objects provided by third parties, such as OS or ActiveX. If an error occurs in a third-party object, you can also get an explanation of the error by searching the web for an error code (-6) or hexadecimal (0xFFFFFFFA).
(3,047 Views)
