User Library displays question mark for icon.
I've added a folder,called My_Library, which contains a labview llb file consisting of contains controls and VIs to the user.lib\_express folder. When want to select a control from the llb file and access it via the ", some of the control icons contain a large question mark as opposed to the controls icon. Why? Also the control is not selectable, yet if you display the controls name, it is displayed.
The same applies if I'm in the wiring diagram and I select a VI though the same mechanism.
Yet if I access the control or VI from the
(3,621 Views)
These sub-vi's were not found when the vi was being load.
You have to replace those by the ones that are in the place where you moved them to and save the main again.
Hope this helps,
Paulo
(3,618 Views)
This usually happens when you moved file or when the files have been moved for you. Or when a folder name was chanded
If for exemple you first open a VI from a temporary location, then open you library, the path may be internally changed.
One fast way to rconnect them is to first open the VIs from the good location, then open the VIs that are calling the first ones, then save the modified VIs
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(3,612 Views)
