Use of Integration VI
dsb@NI wrote:
I recommend path 3 because it requires one less assumption (wavelength spacing to get required accuracy).
Can you explain the term "required accuracy", because I did not see any such requirements.
Chances are that integration of a relatively slowly changing signal with over 1000 points is only very weakly dependent on the actual integration method, especially since the signal is noisy to begin with.
Message 21 of 21
(21 Views)
