Use of Cntrl Q
I have an application where I'm controlling a device via the serial port. To get it to exit from one of the menus, I have to send it a "CNTRL Q". In Labview this is the shortcut for quit and i get the dialog box to exit, save, etc.
Could someone tell me what I need to do to configure labview such that I can use the string constant or other means to send the "CNTRL Q" via the serial port.
Thank you
(2,898 Views)
Take a look in your documentation. CTRL Q is not CTRL Q keys but a combination of one or more ASCII codes in range 0-255
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,894 Views)
Accepted by kwl
According to the ASCII-Table.com hex 11 (decimal 17) is the equivalent of CTRL-Q for terminal programs.
Just create a numeric constant with that value typecast it to string and send it over the comm port.
Ton
My LabVIEW Ideas
(2,870 Views)
You could also make a string control\constant and set to "\codes display" or hex display by right cliking on it. Goto labview help and search for strings, backslash codes display
(2,865 Views)
