Use blinking property node with a pipe indicator from Automation Symbols toolkit
Can I use a blinking property node with a pipe indicator/pump from the Automation Symbols toolkit? How?
(3,115 Views)
I did a quick check. The 2d controls can be set to "blinking" using a property node - same as any boolean. Setting the "blinking" property on the 3d controls doesn't appear to do anything.
Tim
(3,115 Views)
Check that - The 3d control does blink - but only when it is True. Looks like that needs some improvement from NI . . .
(3,115 Views)
The blink works just fine for me.
Ben
See attached
(3,115 Views)
The problem with the 3d control (I checked out a pump), is that the default FALSE color is red. The blinking color is also red, so it didn't appear to blink. You can paint the control another color and it blinks just fine. I couldn't find a way to change the "blink" color. Anyone ???
Tim
(3,115 Views)
See
Tools>>>Options>>>Colors
Ben
(3,115 Views)
