Urgent Help: CUDA initialize device ID problem
Hi
Having a problem with writing and reading data to/from graphic memory...
what does this error mean? And how could I solve it?
(3,468 Views)
You should probably check out the NI Community dedicated to CUDA issues -- https://decibel.ni.com/content/groups/gpu-computing?view=tags&tags=lvcuda.
(3,454 Views)
Why do you confuse people? It is not CUDA problem. File/Directory info says it can not resolve path. I guess LabVIEW simply does not work with %PATH%
Try to run command cmd /C "echo %CUDA_PATH%\bin" with system exec.vi
The standard output is resolved path, that you can work with in LabVIEW
(3,429 Views)
