03-06-2006 05:34 PM
03-06-2006 05:52 PM
What version of LV are you running?
Can you recreate this situation from your backup copies?
I have never read of anyone else reporting this behaviour!
Can you post "before and after" version of the offending VI?
Ben
03-07-2006 03:10 PM
Using Labview 8
I tried to recreate the problem today using one of my earlier backup copies, but was unsuccessful. I don't know where or how it started. I swear I wasn't doing any outlandish or wierd programming. Also, I really don't want to go back starting from my old copy again, mainly because I will lose about a week re-doing all my work (and might I run into the problem again?)
I see that I had these warnings in my earlier programs (and ignored them), and they may not be the cause of my current situation. All I know is I have a program with seemingly zero errors and a broken arrow.
The VIs are too large and numerous to post here and I'd prefer not (due to customer agreement). But I've sent my program(s) to NI Support to see what they can find out. I'm currently waiting for an answer.
I was just wondering if anyone had any ideas here had an idea for a fix.
03-07-2006 03:51 PM
" I've sent my program(s) to NI Support..."
Good!
Please keep us posted on the results.
Ben
03-08-2006 02:20 AM
03-08-2006 05:54 AM
Thanks tst,
I'll have dig through that list.
Ben
08-01-2006 12:37 PM
I am having exactly the same issue. I updated my LabVIEW to 8.0 from 7.0. Everything recompiled fine, but all of a sudden all of my front panel objects are unwired. I went through the program completely and found nothing out of place. I ended up sending the program to the NI engineers to look at because I was at the end of my knowledge rope. Hopefully they will find something. When I do find out what it was, I will post it here.
08-04-2006 09:23 AM
Hi Guys,
Just a follow-up from my end here. This issue I had was resolved by NI support, but they really didn't do anything other than save/upgrade my VI on their computers. Here was the last response I got from NI Support:
"That's great news. Honestly all I did was open the back up file you sent
me in LabVIEW 8 to do the upgrade again. The upgrade conversion process is
sometimes a litttle tricky due to the large architectural changes in
LabVIEW 8, so there's some wiggle room for things to go wrong. My advice
would be to keep frequent backups of your important programs; it sounds
like you are already doing that, which is miles ahead of many people.
Hopefully this won't happen in the future, but if it does, try opening the
VI on another system."
Hopefully your issue gets resolved as well.
08-04-2006 12:05 PM
