Unflattern from XML memory leak
Bug occurs only with VISA resource, other structures look fine.
Seen in LV2011 and LV2012, on PC and RT targets.
Where can i send this bug report? Sorry, newbie for this.
PS: after unloading programm/VI, it didn't reallocate leaked memory. Only restarting/(rebooting RT target) helps.
(2,600 Views)
What is the error message you are getting? I have run the same code but I don't see any error other than the memory started building slowly. Also the way you have used the while loop is not advisable, you can see "Why"
(2,554 Views)
That's pretty much the definition of a memory leak, which is exactly what the poster reported.
(2,544 Views)
