UDP Properties
Is there a way I can find out the 'net address', 'port' and 'multicast address' used to open a UDP port?
And in general, given a UDP port reference, any other properties associated with it?
(2,751 Views)
Hi skol,
when your own VI opens the port why do you need to look after the "properties" used for?
Idea: Why not store all needed information in a cluster together with the given UDP reference?
(2,744 Views)
I could do that, but I was thinking it would be more complete to be able to ask the UDP connection itself. Holding information is not the same as getting information "from the horses mouth" as and when needed. In a dynamic environment, the ability to ask the UDP refnum what its parameters are would be more direct.
I am just asking to eliminate some unnecessary wiring from a cluttered VI.
(2,725 Views)
