Problem with file path control
I choose 'New or existing' in browser option.
If I choose an existing file or folder, it runs OK, but if I just type a name to in order to create a new file or folder, always got error. So, looks like the 'New' mode does not work for me.
Anyone know why this happen? Thanks a lot.
-Dejun
(4,956 Views)
You didn't clarify your error.  Is the path coming out not correct?  When you can select a file that doesn't exist, the dialog box/button doesn't create the file for you.  You would still be responsible for creating the file.
(4,951 Views)
So as to create a New File of a Folder, you ve to use the Open/Create/Replace File or the New Folder primitives respectively.
See the attached Vi in LV 7.1.
- Partha ( CLD until Oct 2027 🙂 )
(4,935 Views)
Also, see the Browse Options I ve set in each of the path controls.
(4,934 Views)
hi
i choose new or exciting option in browse option
and when i run my vi it does not so me in which file it save data.
and when i run my vi it conntiously ask in which file i want to save data .
how t can solve this problem?
thanks
(4,188 Views)
@bijal wrote:
hi
thanks
Care to share some code?  It is really hard to understand issues without good code context.
(4,171 Views)
