UBYTE array to float?
I'm fairly new to Labview, and haven't found an example of this on these forums.  Any help would be greatly appreciated!
I'm reading in a character stream from a serial device, and I wish to convert a 4-byte string (or ubyte array) into a float value.  Is there a way to do this in labview?
For example, I have the array { 0x4b, 0x1c , 0x90, 0x42 } = 0x4b1c9042 = a float value of 72.055260
I can do this in c by:
   char floatarray[] = {0x4b, 0x1c , 0x90, 0x42, 0x00};
   memcpy( &floatvalue, &floatarray, sizeof(float) );
   printf("\nMy float value is %f", floatvalue);  // would give 72.055260 for floatvalue
Is there a way to accomplish this in Labview?
(4,137 Views)
Hi G,
typecast to SGL...(numeric -> data manipulation palette)
Message Edited by GerdW on 08-15-2009 12:31 AM
(4,128 Views)
Accepted by Mr. G
Note that if you're getting the string in that order then you will need to reverse the string first:
Message Edited by smercurio_fc on 08-14-2009 05:33 PM
(4,123 Views)
Ah ha....  The trick is to reverse the string first!!!!!!  I was experimenting with typecasting before I posted, but didn't understand the values it was returning!!!!  Thank you,
Mr. G
(4,117 Views)
