problem with installation
sir
previously i have installed labview in c:/ drive ,due to lack of availability of free space i deleated it and started installing in another drive D:/
but the peoblem is it is not installing in d:drive
suggest me a solution
(2,834 Views)
How about this....
Use the control panel to uninstall labview (rather than deleting it).  You probably want to get rid of all NI software because everything is messed up.
If you have a registry cleaner, run that too.
Then try a clean install.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,814 Views)
And then there is still msiblast in case everything else fails...
(2,812 Views)
